[postgis-tickets] r15447 - Fix handling of EMPTY geometries in btree operator
Sandro Santilli
strk at kbt.io
Fri Jun 23 07:47:13 PDT 2017
Author: strk
Date: 2017-06-23 07:47:13 -0700 (Fri, 23 Jun 2017)
New Revision: 15447
trunk/postgis/lwgeom_btree.c
trunk/regress/operators.sql
trunk/regress/operators_expected
Includes regress test
See #3777
Modified: trunk/postgis/lwgeom_btree.c
--- trunk/postgis/lwgeom_btree.c 2017-06-23 11:40:21 UTC (rev 15446)
+++ trunk/postgis/lwgeom_btree.c 2017-06-23 14:47:13 UTC (rev 15447)
@@ -53,6 +53,7 @@
GSERIALIZED *geom2 = PG_GETARG_GSERIALIZED_P(1);
GBOX box1;
GBOX box2;
+ bool empty1, empty2;
POSTGIS_DEBUG(2, "lwgeom_lt called");
@@ -60,14 +61,19 @@
POSTGIS_DEBUG(3, "lwgeom_lt passed getSRID test");
- gserialized_get_gbox_p(geom1, &box1);
- gserialized_get_gbox_p(geom2, &box2);
+ empty1 = ( gserialized_get_gbox_p(geom1, &box1) == LW_FAILURE );
+ empty2 = ( gserialized_get_gbox_p(geom2, &box2) == LW_FAILURE );
PG_FREE_IF_COPY(geom1, 0);
PG_FREE_IF_COPY(geom2, 1);
POSTGIS_DEBUG(3, "lwgeom_lt getbox2d_p passed");
+ if ( empty1 != empty2 )
+ PG_RETURN_BOOL(FALSE);
if ( ! FPeq(box1.xmin , box2.xmin) )
if (box1.xmin < box2.xmin)
@@ -102,17 +108,23 @@
GBOX box1;
GBOX box2;
POSTGIS_DEBUG(2, "lwgeom_le called");
error_if_srid_mismatch(gserialized_get_srid(geom1), gserialized_get_srid(geom2));
@@ -168,9 +180,10 @@
gbox_init(&box1);
gbox_init(&box2);
@@ -198,17 +211,23 @@
GBOX box1;
GBOX box2;
POSTGIS_DEBUG(2, "lwgeom_ge called");
if (box1.xmin > box2.xmin)
@@ -255,17 +274,23 @@
GBOX box1;
GBOX box2;
POSTGIS_DEBUG(2, "lwgeom_gt called");
@@ -308,17 +333,23 @@
GBOX box1;
GBOX box2;
POSTGIS_DEBUG(2, "lwgeom_cmp called");
Modified: trunk/regress/operators.sql
--- trunk/regress/operators.sql 2017-06-23 11:40:21 UTC (rev 15446)
+++ trunk/regress/operators.sql 2017-06-23 14:47:13 UTC (rev 15447)
@@ -140,4 +140,15 @@
SELECT 'ndovm2', array_agg(i) FROM v WHERE g &&& 'POINTZ(0 0 1)'::geometry
ORDER BY 1;
+-- GROUP BY on empty
+SELECT '#3777', ST_AsText(geom), count(*) FROM (
+SELECT 'POINT(0 0)'::geometry geom UNION ALL
+SELECT 'POINT(0 0)'::geometry UNION ALL
+SELECT 'POINT(0 1)'::geometry UNION ALL
+SELECT 'LINESTRING(0 0,0 1)'::geometry UNION ALL
+SELECT 'GEOMETRYCOLLECTION EMPTY'::geometry UNION ALL
+SELECT 'POINT EMPTY'::geometry
+) foo
+GROUP BY geom ORDER BY 2;
Modified: trunk/regress/operators_expected
--- trunk/regress/operators_expected 2017-06-23 11:40:21 UTC (rev 15446)
+++ trunk/regress/operators_expected 2017-06-23 14:47:13 UTC (rev 15447)
@@ -56,3 +56,7 @@
ndov7|t
ndovm1|{1,2,3,4,5,8}
ndovm2|{1,2,4,6,7}
+#3777|GEOMETRYCOLLECTION EMPTY|2
+#3777|LINESTRING(0 0,0 1)|1
+#3777|POINT(0 0)|3
+#3777|POINT(0 1)|1
