[postgis-tickets] r15452 - Increase LIMIT clause on tests so can more readily catch issues like #3704.
Regina Obe lr at pcorp.us
Fri Jun 23 21:06:19 PDT 2017
Author: robe
Date: 2017-06-23 21:06:19 -0700 (Fri, 23 Jun 2017)
New Revision: 15452
   branches/2.3/doc/xsl/postgis_gardentest.sql.xsl
Modified: branches/2.3/doc/xsl/postgis_gardentest.sql.xsl
--- branches/2.3/doc/xsl/postgis_gardentest.sql.xsl	2017-06-23 22:57:38 UTC (rev 15451)
+++ branches/2.3/doc/xsl/postgis_gardentest.sql.xsl	2017-06-24 04:06:19 UTC (rev 15452)
@@ -32,11 +32,11 @@
 	<xsl:variable name='var_matrix'>'FF1FF0102'</xsl:variable>
 	<xsl:variable name='var_boolean'>false</xsl:variable>
 	<xsl:variable name='var_logtable'>postgis_garden_log23</xsl:variable>
-	<xsl:variable name='var_logupdatesql'>UPDATE <xsl:value-of select="$var_logtable" /> SET log_end = clock_timestamp()
+	<xsl:variable name='var_logupdatesql'>UPDATE <xsl:value-of select="$var_logtable" /> SET log_end = clock_timestamp()
 		FROM (SELECT logid FROM <xsl:value-of select="$var_logtable" /> ORDER BY logid DESC limit 1) As foo
 		WHERE <xsl:value-of select="$var_logtable" />.logid = foo.logid  AND <xsl:value-of select="$var_logtable" />.log_end IS NULL;</xsl:variable>
-	<!-- for queries that result data, we first log the sql in our log table and then use query_to_xml to output it as xml for easy storage
+	<!-- for queries that result data, we first log the sql in our log table and then use query_to_xml to output it as xml for easy storage
 	    with this approach our run statement is always exactly the same -->
 	<xsl:variable name='var_logresultsasxml'>INSERT INTO <xsl:value-of select="$var_logtable" />_output(logid, log_output)
 				SELECT logid, query_to_xml(log_sql, false,false,'') As log_output
@@ -77,7 +77,7 @@
 FROM (VALUES ( ST_GeomFromEWKT('SRID=4326;POLYGONM((-71.1319 42.2503 1,-71.132 42.2502 3,-71.1323 42.2504 -2,-71.1322 42.2505 1,-71.1319 42.2503 0))') ),
 	( ST_GeomFromEWKT('SRID=4326;POLYGONM((-71.1319 42.2512 0,-71.1318 42.2511 20,-71.1317 42.2511 -20,-71.1317 42.251 5,-71.1317 42.2509 4,-71.132 42.2511 6,-71.1319 42.2512 30))') )
 		)	As g(geom))</pgis:gset>
 		<pgis:gset ID='POINTZ' GeometryType='POINTZ'>(SELECT ST_SetSRID(ST_MakePoint(i,j,k),4326) As the_geom
 		FROM generate_series(-10,50,20) As i
 			CROSS JOIN generate_series(40,70, 20) j
@@ -92,48 +92,48 @@
 			CROSS JOIN generate_series(50,70, 20) As j
 			CROSS JOIN generate_series(1,2) As m
-			ORDER BY i, j, i+j+m, m, i*j*m)</pgis:gset>-->
+			ORDER BY i, j, i+j+m, m, i*j*m)</pgis:gset>-->
 		<pgis:gset ID='POLYGONZ' GeometryType='POLYGONZ'>(SELECT geom  As the_geom
 FROM (VALUES ( ST_GeomFromEWKT('SRID=4326;POLYGON((-71.0771 42.3866 1,-71.0767 42.3872 1,-71.0767 42.3863 1,-71.0771 42.3866 1))') ),
 	( ST_GeomFromEWKT('SRID=4326;POLYGON((-71.0775 42.386 2,-71.0773 42.3863 1.75,-71.0773 42.3859 1.75,-71.0775 42.386 2))') )
 		<pgis:gset ID='POLYGONZM' GeometryType='POLYGONZM'>(SELECT geom  As the_geom
 FROM (VALUES ( ST_GeomFromEWKT('SRID=4326;POLYGON((-71.0771 42.3866 1 2,-71.0767 42.3872 1 2.3,-71.0767 42.3863 1 2.3,-71.0771 42.3866 1 2))') ),
 	( ST_GeomFromEWKT('SRID=4326;POLYGON((-71.0775 42.386 2 1.5,-71.0773 42.3863 1.75 1.5,-71.0773 42.3859 1.75 1.5,-71.0775 42.386 2 1.5))') )
 		<pgis:gset ID='POLYHEDRALSURFACE' GeometryType='POLYHEDRALSURFACE'>(SELECT ST_Translate(the_geom,-72.2, 41.755) As the_geom
-'SRID=4326;PolyhedralSurface(
-((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
-((0 0 0, 0 1 0, 1 1 0, 1 0 0, 0 0 0)), ((0 0 0, 1 0 0, 1 0 1, 0 0 1, 0 0 0)),  ((1 1 0, 1 1 1, 1 0 1, 1 0 0, 1 1 0)),
-((0 1 0, 0 1 1, 1 1 1, 1 1 0, 0 1 0)),  ((0 0 1, 1 0 1, 1 1 1, 0 1 1, 0 0 1))
+'SRID=4326;PolyhedralSurface(
+((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
+((0 0 0, 0 1 0, 1 1 0, 1 0 0, 0 0 0)), ((0 0 0, 1 0 0, 1 0 1, 0 0 1, 0 0 0)),  ((1 1 0, 1 1 1, 1 0 1, 1 0 0, 1 1 0)),
+((0 1 0, 0 1 1, 1 1 1, 1 1 0, 0 1 0)),  ((0 0 1, 1 0 1, 1 1 1, 0 1 1, 0 0 1))
 ( ST_GeomFromEWKT(
 ((0 0 0, 0 1 0, 1 1 0, 1 0 0, 0 0 0)) )') ) )
 As foo(the_geom)  ) </pgis:gset>
 		<pgis:gset ID='TRIANGLE' GeometryType='TRIANGLE'>(SELECT ST_GeomFromEWKT(
 'SRID=4326;TRIANGLE ((
-                -71.0821 42.3036,
-                -71.0821 42.3936,
-                -71.0901 42.3036,
+                -71.0821 42.3036,
+                -71.0821 42.3936,
+                -71.0901 42.3036,
                 -71.0821 42.3036
             ))') As the_geom) </pgis:gset>
 		<pgis:gset ID='TIN' GeometryType='TIN'>(SELECT ST_GeomFromEWKT(
 'SRID=4326;TIN (((
-                -71.0821 42.3036 0,
-               -71.0821 42.3036 1,
-                -71.0821 42.3436 0,
+                -71.0821 42.3036 0,
+               -71.0821 42.3036 1,
+                -71.0821 42.3436 0,
                 -71.0821 42.3036 0
-                -71.0831 42.3436 0,
+                -71.0831 42.3436 0,
                 -71.0821 42.3036 0
@@ -149,7 +149,7 @@
 		)	As g(geom) CROSS JOIN generate_series(1,3) As i
 		GROUP BY i
 			)</pgis:gset>
 		<pgis:gset ID='GEOMETRYCOLLECTIONM' GeometryType='GEOMETRYCOLLECTIONM' SkipUnary='1'>(SELECT ST_Collect(geom)  As the_geom
 		FROM (VALUES ( ST_GeomFromEWKT('SRID=4326;MULTIPOLYGONM(((-71.0821 42.3036 2,-71.0822 42.3036 3,-71.082 42.3038 2,-71.0819 42.3037 2,-71.0821 42.3036 2)))') ),
 	( ST_GeomFromEWKT('SRID=4326;POLYGONM((-71.1261 42.2703 1,-71.1257 42.2703 1,-71.1257 42.2701 2,-71.126 42.2701 1,-71.1261 42.2702 1,-71.1261 42.2703 1))') )
@@ -196,8 +196,8 @@
 FROM (VALUES ( ST_GeomFromEWKT('SRID=4326;MULTIPOLYGON(((-71.0821 42.3036 2,-71.0822 42.3036 2,-71.082 42.3038 2,-71.0819 42.3037 2,-71.0821 42.3036 2)))') ),
 	( ST_GeomFromEWKT('SRID=4326;MULTIPOLYGON(((-71.1261 42.2703 1,-71.1257 42.2703 1,-71.1257 42.2701 1,-71.126 42.2701 1,-71.1261 42.2702 1,-71.1261 42.2703 1)))') )
 		<pgis:gset ID='MULTIPOINTM' GeometryType='MULTIPOINTM'>(SELECT ST_Collect(s.the_geom) As the_geom
 		FROM (SELECT ST_SetSRID(ST_MakePointM(i - 0.0821,j + 0.3036,m),4326) As the_geom
 		FROM generate_series(-71,50,15) As i
@@ -215,11 +215,11 @@
 		<pgis:gset ID='MULTIPOLYGONM' GeometryType='MULTIPOLYGONM'>(
 			SELECT ST_GeomFromEWKT('SRID=4326;MULTIPOLYGONM(((0 0 2,10 0 1,10 10 -2,0 10 -5,0 0 -5),(5 5 6,7 5 6,7 7 6,5 7 10,5 5 -2)))')  As the_geom
 			)</pgis:gset>
 		<!-- replacing crasher with a more harmless curve polygon and circular string -->
 		<pgis:gset ID='CURVEPOLYGON' GeometryType='CURVEPOLYGON'>(SELECT ST_GeomFromEWKT('SRID=4326;CURVEPOLYGON(CIRCULARSTRING(-71.0821 42.3036, -71.4821 42.3036, -71.7821 42.7036, -71.0821 42.7036, -71.0821 42.3036),(-71.1821 42.4036, -71.3821 42.6036, -71.3821 42.4036, -71.1821 42.4036) ) ') As the_geom)</pgis:gset>
-		<pgis:gset ID='CURVEPOLYGON2' GeometryType='CURVEPOLYGON'>(SELECT ST_LineToCurve(ST_Buffer(ST_SetSRID(ST_Point(i,j),4326), j))  As the_geom
+		<pgis:gset ID='CURVEPOLYGON2' GeometryType='CURVEPOLYGON'>(SELECT ST_LineToCurve(ST_Buffer(ST_SetSRID(ST_Point(i,j),4326), j))  As the_geom
 		        FROM generate_series(-10,50,10) As i
 					CROSS JOIN generate_series(40,70, 20) As j
 					ORDER BY i, j, i*j)
@@ -235,12 +235,12 @@
 			UNION ALL SELECT ST_GeomFromText('MULTILINESTRING EMPTY',4326) As the_geom
 		</pgis:gset>
 		<pgis:gset ID="Empty Geometry Collection" GeometryType="GEOMETRY" createtable="false">
 		 (SELECT ST_GeomFromText('GEOMETRYCOLLECTION EMPTY',4326) As the_geom )
 		</pgis:gset>
 		<pgis:gset ID="Single NULL" GeometryType="GEOMETRY" createtable="false">(SELECT CAST(Null As geometry) As the_geom)</pgis:gset>
 		<pgis:gset ID="Multiple NULLs" GeometryType="GEOMETRY" createtable="false">(SELECT CAST(Null As geometry) As the_geom FROM generate_series(1,4) As foo)</pgis:gset>
@@ -264,14 +264,14 @@
 					ORDER BY i, j, i*j)</pgis:gset>
 		<pgis:gset ID="Collection of Empties" GeometryType="GEOMETRY" createtable="false">(SELECT ST_Collect(ST_GeomFromText('GEOMETRYCOLLECTION EMPTY',4326), ST_GeomFromText('POLYGON EMPTY',4326)) As the_geom
 			UNION ALL SELECT ST_COLLECT(ST_GeomFromText('POLYGON EMPTY',4326),ST_GeomFromText('TRIANGLE EMPTY',4326))  As the_geom
 			UNION ALL SELECT ST_Collect(ST_GeomFromText('POINT EMPTY',4326), ST_GeomFromText('MULTIPOINT EMPTY',4326)) As the_geom
 		)</pgis:gset>
 		<pgis:gset ID="POLYGON EMPTY" GeometryType="POLYGON" createtable="false">(SELECT ST_GeomFromText('POLYGON EMPTY',4326) As the_geom)</pgis:gset>
 	<pgis:gardencrashers>
@@ -298,7 +298,7 @@
 			FROM (<xsl:value-of select="." />) As foo limit 1;
 	SELECT AddGeometryColumn('pgis_garden','the_geom_multi',ST_SRID(the_geom),GeometryType(ST_Multi(the_geom)),ST_CoordDim(the_geom))
 			FROM (<xsl:value-of select="." />) As foo limit 1;</xsl:variable>
-INSERT INTO <xsl:value-of select="$var_logtable" />(log_label, func, g1, log_start, log_sql)
+INSERT INTO <xsl:value-of select="$var_logtable" />(log_label, func, g1, log_start, log_sql)
 VALUES('<xsl:value-of select="$log_label" /> AddGeometryColumn','AddGeometryColumn', '<xsl:value-of select="@GeometryType" />', clock_timestamp(),
     '<xsl:call-template name="escapesinglequotes"><xsl:with-param name="arg1"><xsl:value-of select="$var_sql" /></xsl:with-param></xsl:call-template>');
 BEGIN;
@@ -323,7 +323,7 @@
 SELECT '<xsl:value-of select="$log_label" /> geometry brin index: End Testing <xsl:value-of select="@ID" />';
 VALUES('<xsl:value-of select="$log_label" /> insert data Geometry','insert data', '<xsl:value-of select="@ID" />', clock_timestamp(), '<xsl:call-template name="escapesinglequotes">
  <xsl:with-param name="arg1">INSERT INTO pgis_garden(the_geom, the_geom_multi)
 	SELECT the_geom, ST_Multi(the_geom)
@@ -334,7 +334,7 @@
 	FROM (<xsl:value-of select="." />) As foo;
 	<xsl:value-of select="$var_logupdatesql" />
-COMMIT;
+COMMIT;
 SELECT '<xsl:value-of select="$log_label" /> Geometry index overlaps: Start Testing <xsl:value-of select="@ID" />';
@@ -346,27 +346,27 @@
 COMMIT;
 SELECT '<xsl:value-of select="$log_label" /> geometry index overlaps: End Testing <xsl:value-of select="@ID" />';
-INSERT INTO <xsl:value-of select="$var_logtable" />(log_label, func, g1, log_start)
+INSERT INTO <xsl:value-of select="$var_logtable" />(log_label, func, g1, log_start)
 VALUES('<xsl:value-of select="$log_label" /> UpdateGeometrySRID','UpdateGeometrySRID', '<xsl:value-of select="@GeometryType" />', clock_timestamp());
 BEGIN;
 	SELECT UpdateGeometrySRID('pgis_garden', 'the_geom', 4269);
 COMMIT;
 VALUES('<xsl:value-of select="$log_label" /> vacuum analyze Geometry','vacuum analyze Geometry', '<xsl:value-of select="@ID" />', clock_timestamp());
 VACUUM ANALYZE pgis_garden;
 VALUES('<xsl:value-of select="$log_label" /> DropGeometryColumn','DropGeometryColumn', '<xsl:value-of select="@GeometryType" />', clock_timestamp());
 BEGIN;
 	SELECT DropGeometryColumn ('pgis_garden','the_geom');
 COMMIT;
 VALUES('<xsl:value-of select="$log_label" /> DropGeometryTable','DropGeometryTable', '<xsl:value-of select="@ID" />', clock_timestamp());
 BEGIN;
@@ -441,7 +441,7 @@
 		<xsl:for-each select="document('')//pgis:gardens/pgis:gset">
 		<xsl:choose>
 			  <xsl:when test="contains($fndef, 'geography')">
-			  INSERT INTO <xsl:value-of select="$var_logtable" />(log_label, func, g1, g2, log_start, log_sql)
+			  INSERT INTO <xsl:value-of select="$var_logtable" />(log_label, func, g1, g2, log_start, log_sql)
 			  	VALUES('<xsl:value-of select="$log_label" /> Geography <xsl:value-of select="$geom1id" /><xsl:text> </xsl:text><xsl:value-of select="@ID" />','<xsl:value-of select="$fnname" />', '<xsl:value-of select="$geom1id" />','<xsl:value-of select="@ID" />', clock_timestamp(),
  <xsl:with-param name="arg1">SELECT ST_AsEWKT(foo1.the_geom) as ewktgeog1, ST_AsEWKT(foo2.the_geom) as ewktgeog2, geography(foo1.the_geom) <xsl:value-of select="$fnname" /> geography(foo2.the_geom) As geog1_op_geog2
@@ -458,7 +458,7 @@
 			</xsl:when>
 			<xsl:otherwise>
 			SELECT 'Geometry <xsl:value-of select="$fnname" /><xsl:text> </xsl:text><xsl:value-of select="@ID" />: Start Testing <xsl:value-of select="$geom1id" />, <xsl:value-of select="@ID" />';
 			  	VALUES('<xsl:value-of select="$log_label" /> Geometry <xsl:value-of select="$geom1id" /><xsl:text> </xsl:text><xsl:value-of select="@ID" />','<xsl:value-of select="$fnname" />', '<xsl:value-of select="$geom1id" />','<xsl:value-of select="@ID" />', clock_timestamp(),
  <xsl:with-param name="arg1">SELECT ST_AsEWKT(foo1.the_geom) as ewktgeom1, ST_AsEWKT(foo2.the_geom) as ewktgeom2, foo1.the_geom <xsl:value-of select="$fnname" /> foo2.the_geom As geom1_op_geom2
@@ -508,7 +508,7 @@
 					</xsl:otherwise>
 				  </xsl:choose>
 				</xsl:variable>
 				<!-- is a window function -->
 				<xsl:variable name='over_clause'>
 					 <xsl:choose>
@@ -524,14 +524,14 @@
 				<xsl:choose>
 <!--Test functions that take no arguments and take no geometries/geographies -->
 	<xsl:when test="($numparamgeoms = '0' and $numparamgeogs = '0') and not(contains($fnexclude,funcdef/function))">SELECT  'Starting <xsl:value-of select="funcdef/function" />(<xsl:value-of select="$fnargs" />)';
-INSERT INTO <xsl:value-of select="$var_logtable" />(log_label, func, log_start, log_sql)
+INSERT INTO <xsl:value-of select="$var_logtable" />(log_label, func, log_start, log_sql)
 			  	VALUES('<xsl:value-of select="$log_label" /> <xsl:value-of select="$geoftype" />','<xsl:value-of select="$fnname" />', clock_timestamp(),
  <xsl:with-param name="arg1">SELECT  <xsl:value-of select="funcdef/function" />(<xsl:value-of select="$fnfakeparams" />) As output;</xsl:with-param></xsl:call-template>');
 BEGIN;
     <xsl:value-of select="$var_logresultsasxml" />
-	<xsl:value-of select="$var_logupdatesql" />
+	<xsl:value-of select="$var_logupdatesql" />
 COMMIT;
 SELECT  'Ending <xsl:value-of select="funcdef/function" />(<xsl:value-of select="$fnargs" />)';
 	</xsl:when>
@@ -542,17 +542,17 @@
 		SELECT '<xsl:value-of select="$geoftype" /> <xsl:value-of select="$fnname" /><xsl:text> </xsl:text><xsl:value-of select="@ID" />: Start Testing';
-	INSERT INTO <xsl:value-of select="$var_logtable" />(log_label, func, g1, log_start, log_sql)
+	INSERT INTO <xsl:value-of select="$var_logtable" />(log_label, func, g1, log_start, log_sql)
 			  	VALUES('<xsl:value-of select="$log_label" /> <xsl:value-of select="$geoftype" />  <xsl:text> </xsl:text><xsl:value-of select="@ID" /><xsl:text> </xsl:text>','<xsl:value-of select="$fnname" />', '<xsl:value-of select="@ID" />', clock_timestamp(),
  <xsl:with-param name="arg1">SELECT <xsl:value-of select="$fnname" />(<xsl:value-of select="$fnfakeparams" />)<xsl:value-of select="$over_clause" />  As result
 							FROM (<xsl:value-of select="." />) As foo1
-				LIMIT 3;</xsl:with-param></xsl:call-template>');
+				LIMIT 10;</xsl:with-param></xsl:call-template>');
 BEGIN;
-COMMIT;
-			SELECT '<xsl:value-of select="$geoftype" /> <xsl:value-of select="$fnname" /><xsl:text> </xsl:text><xsl:value-of select="@ID" />: End Testing';
+COMMIT;
+			SELECT '<xsl:value-of select="$geoftype" /> <xsl:value-of select="$fnname" /><xsl:text> </xsl:text><xsl:value-of select="@ID" />: End Testing';
 		</xsl:for-each>
 	</xsl:when>
@@ -567,12 +567,12 @@
 			<xsl:choose>
 			  <xsl:when test="($numparamgeogs > '0' or $numparamgeoms > '0')">
 			  	VALUES('<xsl:value-of select="$log_label" /> <xsl:value-of select="$geoftype" /> <xsl:text> </xsl:text> <xsl:value-of select="@ID" />','<xsl:value-of select="$fnname" />','<xsl:value-of select="$geom1id" />', '<xsl:value-of select="@ID" />', clock_timestamp(),
  <xsl:with-param name="arg1">SELECT <xsl:value-of select="$fnname" />(<xsl:value-of select="$fnfakeparams" />) As result, ST_AsText(foo1.the_geom) As ref1_geom, ST_AsText(foo2.the_geom) As ref2_geom
 	FROM (<xsl:value-of select="$from1" />) As foo1 CROSS JOIN (<xsl:value-of select="." />) As foo2
-			LIMIT 2;</xsl:with-param></xsl:call-template>');
 			BEGIN;
@@ -580,7 +580,7 @@
 			COMMIT;
 			</xsl:when>
 			  <xsl:otherwise>
 			  	VALUES('<xsl:value-of select="$log_label" /> Other <xsl:text> </xsl:text><xsl:value-of select="$geom1id" /><xsl:text> </xsl:text><xsl:value-of select="@ID" />','<xsl:value-of select="$fnname" />', '<xsl:value-of select="$geom1id" />','<xsl:value-of select="@DI" />', clock_timestamp(),
  <xsl:with-param name="arg1">SELECT <xsl:value-of select="$fnname" />(<xsl:value-of select="$fnfakeparams" />)</xsl:with-param></xsl:call-template>');
@@ -592,7 +592,7 @@
 				COMMIT;
 			  </xsl:otherwise>
 			</xsl:choose>
 	SELECT '<xsl:value-of select="$fnname" />(<xsl:value-of select="$fnargs" />) <xsl:text> </xsl:text> <xsl:value-of select="@ID" />: End Testing <xsl:value-of select="$geom1id" />, <xsl:value-of select="@GeometryType" />';
 		<xsl:text>
@@ -733,7 +733,7 @@
 			</xsl:for-each>
 		</xsl:for-each>
 	</xsl:template>
 	<!-- copied from http://www.thedumbterminal.co.uk/php/knowledgebase/?action=view&id=94 -->
     <xsl:template name="escapesinglequotes">
      <xsl:param name="arg1"/>
