[postgis-tickets] [PostGIS] #3702: ST_LineToCurve not working as documented
trac at osgeo.org
Fri Jun 23 21:34:20 PDT 2017
Reporter: mkuhn | Owner: robe
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.3.3
Component: documentation | Version: 2.3.x
Resolution: fixed | Keywords:
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"15455" 15455]:
#!CommitTicketReference repository="" revision="15455"
Update 3D example and put a note about function may return the same
geometry.
References #3702 for PostGIS 2.4 (trunk)
Last commit was for PostGIS 2.3.3 (mistakenly noted as 2.4)
Closes #3702
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3702#comment:4>
