[postgis-tickets] [PostGIS] #3733: Cannot ANALYZE table w/ valid features in it
trac at osgeo.org
Fri Jun 23 22:19:21 PDT 2017
Reporter: pramsey | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.3.3
Component: postgis | Version: 2.3.x
Resolution: | Keywords:
Comment (by robe):
We can add this to regress tests I guess after you have tested.
CREATE TABLE test_awful(gid serial, geom geometry);
INSERT INTO test_awful(geom)
VALUES ( 'POINT ZM (1463702.128 517438.510000008 0
-1.79769313486232e+308)'::geometry),
('POINT ZM (1234886.324 454719.691000004 0
('POINT ZM (1230629.645 468753.839000007 0
-1.79769313486232e+308)'::geometry ),
('POINT ZM (1243683.988 466816.384999998 0
-1.79769313486232e+308)'::geometry );
analyze test_awful;
I assume the notice:
NOTICE: no non-null/empty features, unable to compute statistics
is what you are referring to.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3733#comment:1>
