[postgis-tickets] r15458 - change doco for Geocode_Intersection to agree with function definition.
Regina Obe lr at pcorp.us
Fri Jun 23 22:31:35 PDT 2017
Author: robe
Date: 2017-06-23 22:31:35 -0700 (Fri, 23 Jun 2017)
New Revision: 15458
   branches/2.3/doc/extras_tigergeocoder.xml
Closes #3717 for PostGIS 2.3.3
Modified: branches/2.3/doc/extras_tigergeocoder.xml
--- branches/2.3/doc/extras_tigergeocoder.xml	2017-06-24 04:58:24 UTC (rev 15457)
+++ branches/2.3/doc/extras_tigergeocoder.xml	2017-06-24 05:31:35 UTC (rev 15458)
@@ -390,7 +390,7 @@
             <paramdef><type>text </type> <parameter> in_state</parameter></paramdef>
             <paramdef choice="opt"><type>text </type> <parameter> in_city</parameter></paramdef>
             <paramdef choice="opt"><type>text </type> <parameter> in_zip</parameter></paramdef>
-            <paramdef choice="opt"><type>integer </type> <parameter>max_results=10</parameter></paramdef>
+            <paramdef choice="opt"><type>integer </type> <parameter>num_results=10</parameter></paramdef>
             <paramdef><type>norm_addy </type> <parameter>OUT addy</parameter></paramdef>
             <paramdef><type>geometry </type> <parameter>OUT geomout</parameter></paramdef>
             <paramdef><type>integer </type> <parameter>OUT rating</parameter></paramdef>
@@ -732,7 +732,7 @@
           </listitem>
         </orderedlist>
         <para>Availability: 2.0.0 to support Tiger 2010 structured data and load census tract (tract), block groups (bg), and blocks (tabblocks) tables .</para>
-        <note><para>If you are using pgAdmin 3, be warned that by default pgAdmin 3 truncates long text.  To fix, change
+        <note><para>If you are using pgAdmin 3, be warned that by default pgAdmin 3 truncates long text.  To fix, change
          <emphasis>File -> Options -> Query Tool -> Query Editor - > Max. characters per column</emphasis> to larger than 50000 characters.</para></note>
