[postgis-tickets] [PostGIS] #3719: Error: Invalid number of points in LinearRing
PostGIS trac at osgeo.org
Thu Jun 29 02:00:49 PDT 2017
  Reporter:  tiiipponen  |      Owner:  pramsey
      Type:  defect      |     Status:  new
  Priority:  medium      |  Milestone:  PostGIS 2.4.0
 Component:  postgis     |    Version:  2.3.x
Resolution:              |   Keywords:
Changes (by robe):
 * milestone:  PostGIS 2.3.3 => PostGIS 2.4.0
Comment:
 strk you think your work in #3772 can accommodate this issue.
 It's still a problem in after I test with trunk code, but since you are in
 that area anyway, you might have some thoughts on this.
 anyrate I'm pushing this to 2.4 since 2.4 lwstroke is different from 2.3
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3719#comment:2>
