[postgis-tickets] r15474 - bump to 2.3.4dev
Regina Obe lr at pcorp.us
Fri Jun 30 23:49:42 PDT 2017
Author: robe
Date: 2017-06-30 23:49:42 -0700 (Fri, 30 Jun 2017)
New Revision: 15474
   branches/2.3/Version.config
   branches/2.3/extensions/upgradeable_versions.mk
bump to 2.3.4dev
Modified: branches/2.3/Version.config
--- branches/2.3/Version.config	2017-07-01 06:35:38 UTC (rev 15473)
+++ branches/2.3/Version.config	2017-07-01 06:49:42 UTC (rev 15474)
@@ -5,7 +5,7 @@
 POSTGIS_MAJOR_VERSION=2
 POSTGIS_MINOR_VERSION=3
-POSTGIS_MICRO_VERSION=3
+POSTGIS_MICRO_VERSION=4dev
 # Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
 # when changing POSTGIS_MINOR_VERSION
Modified: branches/2.3/extensions/upgradeable_versions.mk
--- branches/2.3/extensions/upgradeable_versions.mk	2017-07-01 06:35:38 UTC (rev 15473)
+++ branches/2.3/extensions/upgradeable_versions.mk	2017-07-01 06:49:42 UTC (rev 15474)
@@ -25,7 +25,8 @@
 	2.2.5 \
 	2.3.0 \
 	2.3.1 \
-    2.3.2
+  2.3.2 \
+	2.3.3
 # This is to avoid forcing "check-installed-upgrades" as a default
 # rule, see https://trac.osgeo.org/postgis/ticket/3420
