[postgis-tickets] [PostGIS] #3727: Hard upgrade failed - pg_restore: [archiver] could not find entry for ID 6
trac at osgeo.org
Thu Mar 9 06:48:55 PST 2017
Reporter: milosh | Owner: strk
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.3.3
Component: build/upgrade/install | Version: 2.3.x
Resolution: invalid | Keywords:
Changes (by milosh):
* status: new => closed
* resolution: => invalid
Comment:
Found the root cause:
Foreign Key constraint with new line in its name created by hand in the
distant past by copypasting sql from wrapped terminal window.
ALTER TABLE "provoz_provozovna" ADD CONSTRAINT
"infrastruktura_id_refs_id_4e49f6
6e" FOREIGN KEY ("infrastruktura_id") REFERENCES "provoz_infrastruktura"
("id")
This will appear as:
15128; 2606 5687308 FK CONSTRAINT public infrastruktura_id_refs_id_4e49f6
6e postgres
in the TOC file and the archiver will fail trying to lookup item ID "6" in
the backup.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3727#comment:2>
