[postgis-tickets] r15390 - ST_AsMVT Document JSONB support
bjorn at wololo.org
bjorn at wololo.org
Thu May 4 13:22:17 PDT 2017
Author: bjornharrtell
Date: 2017-05-04 13:22:16 -0700 (Thu, 04 May 2017)
New Revision: 15390
trunk/doc/reference_output.xml
References #3749
Modified: trunk/doc/reference_output.xml
--- trunk/doc/reference_output.xml 2017-05-04 18:40:26 UTC (rev 15389)
+++ trunk/doc/reference_output.xml 2017-05-04 20:22:16 UTC (rev 15390)
@@ -1422,6 +1422,11 @@
Other row data will be encoded as attributes.
</para>
+ <para>The <ulink url="https://www.mapbox.com/vector-tiles/">Mapbox Vector Tile</ulink> format can store features with a different
+ set of attributes per feature. To make use of this feature supply a JSONB column in the row data containing Json objects one level
+ deep. The keys and values in the object will be parsed into feature attributes.
+ </para>
<para><varname>name</varname> is the name of the Layer</para>
<para><varname>extent</varname> is the tile extent in screen space as defined by the specification. If NULL it will default to 4096.</para>
<para><varname>geom_name</varname> is the name of the geometry column in the row data.</para>
