[postgis-tickets] [PostGIS] #3751: Parallel support for aggregates with transitions
PostGIS trac at osgeo.org
Fri May 5 05:19:41 PDT 2017
 Reporter:  robe         |      Owner:  pramsey
     Type:  enhancement  |     Status:  new
 Priority:  high         |  Milestone:  PostGIS 2.4.0
Component:  postgis      |    Version:  2.3.x
 Keywords:               |
 I didn't think aggregate functions that use transitions (take internal as
 input) are parallelizable.
 Turns out that even in PostgreSQL 9.6 it is possible to do so as long as
 you define a serialize and deserialize function for them.  These are new
 args to CREATE AGGREGATE in 9.6
 https://www.postgresql.org/docs/9.6/static/sql-createaggregate.html
 CREATE AGGREGATE name ( [ argmode ] [ argname ] arg_data_type [ , ... ] )
     SFUNC = sfunc,
     STYPE = state_data_type
     [ , SSPACE = state_data_size ]
     [ , FINALFUNC = ffunc ]
     [ , FINALFUNC_EXTRA ]
     [ , COMBINEFUNC = combinefunc ]
     [ , SERIALFUNC = serialfunc ]
     [ , DESERIALFUNC = deserialfunc ]
     [ , INITCOND = initial_condition ]
     [ , MSFUNC = msfunc ]
     [ , MINVFUNC = minvfunc ]
     [ , MSTYPE = mstate_data_type ]
     [ , MSSPACE = mstate_data_size ]
     [ , MFINALFUNC = mffunc ]
     [ , MFINALFUNC_EXTRA ]
     [ , MINITCOND = minitial_condition ]
     [ , SORTOP = sort_operator ]
     [ , PARALLEL = { SAFE | RESTRICTED | UNSAFE } ]
 From the docs
 serialfunc
     An aggregate function whose state_data_type is internal can
 participate in parallel aggregation only if it has a serialfunc function,
 which must serialize the aggregate state into a bytea value for
 transmission to another process. This function must take a single argument
 of type internal and return type bytea. A corresponding deserialfunc is
 also required.
 deserialfunc
     Deserialize a previously serialized aggregate state back into
 state_data_type. This function must take two arguments of types bytea and
 internal, and produce a result of type internal. (Note: the second,
 internal argument is unused, but is required for type safety reasons.)
 It would be really nice if we can do this because then we have the
 possiblity of making really costly aggregates like ST_Union  and the
 various raster aggregates parallelizable.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3751>
