[postgis-tickets] [PostGIS] #3753: Gist penalty misbehaves if points are inserted in gridded ordered fashion
trac at osgeo.org
Thu May 11 05:54:29 PDT 2017
Reporter: komzpa | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.3.3
Component: postgis | Version: 2.3.x
Resolution: | Keywords:
Changes (by robe):
* owner: pramsey => robe
Comment:
I think I had the same issue when doing a ubuntu upgrade recently but
forget how I got around the gdal issue.
Anyway as you said it's a gdal install issue nothing to do with your
patch. I'll take a look at your patch and commit if it passes my 9.4-9.6
tests.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3753#comment:2>
