[postgis-tickets] [PostGIS] #3764: PostGIS topology failures on PostgreSQL 10
trac at osgeo.org
Fri May 26 01:46:39 PDT 2017
Reporter: robe | Owner: robe
Type: defect | Status: assigned
Priority: blocker | Milestone: PostGIS 2.4.0
Component: topology | Version: trunk
Resolution: | Keywords:
Comment (by robe):
Okay did some checking. I think topology is suffering from the same issue
as what raster was. namely the CASE WHEN set returning behavior changes
in PostgreSQL 10. I think I isolated the issue to the
topology.totopogeom(
ageom geometry,
tg topogeometry,
atolerance double precision DEFAULT 0) function, there is a case
statement that uses set returning function topogeo_addpolygon.
FOR rec2 IN SELECT CASE
WHEN rec.dims = 0 THEN
topology.topogeo_addPoint(atopology, rec.geom, tolerance)
WHEN rec.dims = 1 THEN
topology.topogeo_addLineString(atopology, rec.geom, tolerance)
WHEN rec.dims = 2 THEN
topology.topogeo_addPolygon(atopology, rec.geom, tolerance)
END as primitive
LOOP
What I discovered was the SRF gets called even if the condition is not
met.
I by the way did end up complaining about this because though it is sorta
documented in the release notes, it seems counter intuitive in that it
behaves differently with constants.
https://www.postgresql.org/message-
id/000001d2d5de%24d8d66170%248a832450%24%40pcorp.us
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3764#comment:4>
