[postgis-tickets] [PostGIS] #3764: PostGIS topology failures on PostgreSQL 10
trac at osgeo.org
Fri May 26 12:35:20 PDT 2017
Reporter: robe | Owner: robe
Type: defect | Status: closed
Priority: blocker | Milestone: PostGIS 2.4.0
Component: topology | Version: trunk
Resolution: fixed | Keywords:
Changes (by robe):
* status: assigned => closed
* resolution: => fixed
Comment:
In [changeset:"15406" 15406]:
#!CommitTicketReference repository="" revision="15406"
Fix topology PostgreSQL 10 regress errors
Change CASE WHEN SRF to use constant
Evidentally they also removed a bunch of columns from sequence table
struct
I'm guessing has to do with intro of IDENTITY column type, so had to
revise copytopology regress
Closes #3764
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3764#comment:5>
