[postgis-tickets] [PostGIS] #3933: [raster] Errors in examples of doc for ST_Neighborhood
PostGIS trac at osgeo.org
Wed Nov 22 06:18:09 PST 2017
 Reporter:  lrohr                                |      Owner:  robe
     Type:  defect                               |     Status:  new
 Priority:  low                                  |  Milestone:
Component:  documentation                        |    Version:  2.4.x
 Keywords:  postgis, documentation,              |
  ST_Neighborhood, raster                        |
 I spotted 3 errors in the examples cited in the documentation for
 ST_Neighborhood:
 * First example: The result should be {{NULL,1,1},{1,1,1},{1,NULL,1}}.
 Reproduce: Execute query (copy-paste) on a server.
 * Third example: There is a "SELECT" missing between lines 5 and 6. Copy-
 pasting the query as is raises a syntax error. Correct:
 FROM (
         SELECT
                 ST_SetValues(
 * Third example: The result should be {{1,1,0},{0,1,1},{1,1,1}}.
 Reproduce: Execute query (copy-paste) with the correction above on a
 server.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3933>
