[postgis-tickets] [PostGIS] #3843: st_RemoveRepeatedPoints misses duplicate in polygon
trac at osgeo.org
Wed Nov 22 07:53:53 PST 2017
Reporter: crispond | Owner: pramsey
Type: defect | Status: reopened
Priority: medium | Milestone: PostGIS 2.4.0
Component: postgis | Version: 2.4.x
Resolution: | Keywords: st_RemoveRepeatedPoints
Changes (by zimirrr):
* status: closed => reopened
* version: 2.2.x => 2.4.x
* resolution: fixed =>
Comment:
We've found same problem with ST_RemoveRepeatedPoints.
This sql fails to drop duplicated node '''90.352327 23.79429''':
{{{#!sql
SELECT ST_AsText(ST_RemoveRepeatedPoints('POLYGON((90.352399
23.794183,90.352332 23.79418,90.352327 23.79429,90.352327
23.79429,90.352399 23.794183))'))
But on linestring it works:
{{{#!sql
SELECT ST_AsText(ST_RemoveRepeatedPoints('LINESTRING(90.352399
23.79429,90.352399 23.794183)'))
Was tested it on:
1. "POSTGIS="2.4.1 r16012" PGSQL="100" GEOS="3.6.2-CAPI-1.10.2 4d2925d"
PROJ="Rel. 4.9.3, 15 August 2016" GDAL="GDAL 2.2.2, released 2017/09/15"
LIBXML="2.7.8" LIBJSON="0.12" LIBPROTOBUF="1.2.1" RASTER"
2. "POSTGIS="2.3.3 r15473" GEOS="3.6.1-CAPI-1.10.1 r4317" PROJ="Rel.
4.9.1, 04 March 2015" GDAL="GDAL 2.2.1, released 2017/06/23"
LIBXML="2.7.8" LIBJSON="0.12" RASTER"
3. "POSTGIS="2.3.2 r15302" GEOS="3.6.1-CAPI-1.10.1 r0" PROJ="Rel. 4.9.3,
15 August 2016" GDAL="GDAL 2.2.0, released 2017/04/28" LIBXML="2.9.4"
LIBJSON="0.12.1" RASTER"
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3843#comment:7>
