[postgis-tickets] r15904 - lwtriangle_is_repeated_points should be local to lwtriangle.c
Paul Ramsey
pramsey at cleverelephant.ca
Thu Oct 5 06:35:38 PDT 2017
Author: pramsey
Date: 2017-10-05 06:35:38 -0700 (Thu, 05 Oct 2017)
New Revision: 15904
trunk/liblwgeom/liblwgeom.h.in
trunk/liblwgeom/lwtriangle.c
Modified: trunk/liblwgeom/liblwgeom.h.in
--- trunk/liblwgeom/liblwgeom.h.in 2017-10-05 13:22:06 UTC (rev 15903)
+++ trunk/liblwgeom/liblwgeom.h.in 2017-10-05 13:35:38 UTC (rev 15904)
@@ -1658,8 +1658,6 @@
extern LWGEOM* lwgeom_remove_repeated_points(const LWGEOM *in, double tolerance);
-extern char lwtriangle_is_repeated_points(LWTRIANGLE *triangle);
* Swap ordinate values in every vertex of the geometry.
Modified: trunk/liblwgeom/lwtriangle.c
--- trunk/liblwgeom/lwtriangle.c 2017-10-05 13:22:06 UTC (rev 15903)
+++ trunk/liblwgeom/lwtriangle.c 2017-10-05 13:35:38 UTC (rev 15904)
@@ -130,6 +130,19 @@
return r;
+static char
+lwtriangle_is_repeated_points(LWTRIANGLE *triangle)
+ char ret;
+ POINTARRAY *pa;
+ pa = ptarray_remove_repeated_points(triangle->points, 0.0);
+ ret = ptarray_same(pa, triangle->points);
+ ptarray_free(pa);
+ return ret;
* Construct a triangle from a LWLINE being
* the shell
@@ -158,19 +171,6 @@
return ret;
-char
-lwtriangle_is_repeated_points(LWTRIANGLE *triangle)
- char ret;
- POINTARRAY *pa;
- pa = ptarray_remove_repeated_points(triangle->points, 0.0);
- ret = ptarray_same(pa, triangle->points);
- ptarray_free(pa);
- return ret;
int lwtriangle_is_empty(const LWTRIANGLE *triangle)
if ( !triangle->points || triangle->points->npoints < 1 )
