[postgis-tickets] r15905 - Really only install symlinks for upgrade paths
Sandro Santilli
strk at kbt.io
Thu Oct 5 07:00:03 PDT 2017
Author: strk
Date: 2017-10-05 07:00:02 -0700 (Thu, 05 Oct 2017)
New Revision: 15905
trunk/extensions/postgis/Makefile.in
Also only symlink the "next" hacks, and do all of this at
`make install` time, not bothering at `make` time
Modified: trunk/extensions/postgis/Makefile.in
--- trunk/extensions/postgis/Makefile.in 2017-10-05 13:35:38 UTC (rev 15904)
+++ trunk/extensions/postgis/Makefile.in 2017-10-05 14:00:02 UTC (rev 15905)
@@ -22,7 +22,7 @@
$(GREP) "[a-zA-Z]" | \
$(PERL) -pe 's/(\d+[a-zA-Z]+)\d*/\1/'
-DATA = $(wildcard sql/*--*.sql)
+UPGRADE_SCRIPTS = $(wildcard sql/*--*.sql)
#DOCS = $(wildcard ../../doc/html/*.html)
PG_CONFIG = @PG_CONFIG@
@@ -32,7 +32,7 @@
CURV_big=@POSTGIS_MAJOR_VERSION@@POSTGIS_MINOR_VERSION@
-all: sql/$(EXTENSION)--$(EXTVERSION).sql sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql sql/$(EXTENSION)--$(EXTVERSION)--$(EXTVERSION)next.sql sql/$(EXTENSION)--$(EXTVERSION)next--$(EXTVERSION).sql sql_minor_upgrade
+all: sql/$(EXTENSION)--$(EXTVERSION).sql sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql
sql/$(EXTENSION).sql: sql_bits/postgis.sql sql_bits/postgis_comments.sql sql_bits/rtpostgis.sql sql_bits/spatial_ref_sys_config_dump.sql sql_bits/raster_comments.sql sql_bits/spatial_ref_sys.sql
mkdir -p sql
@@ -47,12 +47,6 @@
mkdir -p sql
cat ../../postgis/postgis.sql ../../raster/rt_pg/rtpostgis.sql | $(PERL) ../../utils/create_unpackaged.pl postgis > $@
-#this is a cludge to allow upgrading from same SVN to same SVN
-sql/$(EXTENSION)--$(EXTVERSION)--$(EXTVERSION)next.sql: sql_bits/postgis_extension_upgrade_minor.sql
- cp $< $@
-sql/$(EXTENSION)--$(EXTVERSION)next--$(EXTVERSION).sql: sql_bits/postgis_extension_upgrade_minor.sql
- cp $< $@
#strip BEGIN/COMMIT since these are not allowed in extensions
sql_bits/spatial_ref_sys.sql: ../../spatial_ref_sys.sql
$(PERL) -pe 's/BEGIN\;//g ; s/COMMIT\;//g' $< > $@
@@ -94,10 +88,18 @@
printf '\\echo Use "CREATE EXTENSION $(EXTENSION)" to load this file. \\quit\n' > $@
cat $^ >> $@
-sql_minor_upgrade: sql_bits/postgis_extension_upgrade_minor.sql
- cp $< sql/$(EXTENSION)--ANY-$(EXTVERSION).sql
+install: install-upgrade-paths
+# The "next" lines are a cludge to allow upgrading between different
+# revisions of the same version
+install-upgrade-paths: sql_bits/postgis_extension_upgrade_minor.sql
+ todir='$(DESTDIR)$(datadir)/$(datamoduledir)'; \
+ tpl='$(EXTENSION)--ANY-$(EXTVERSION).sql'; \
+ ln -fs "$${tpl}" $${todir}/$(EXTENSION)--$(EXTVERSION)--$(EXTVERSION)next.sql; \
+ ln -fs "$${tpl}" $${todir}/$(EXTENSION)--$(EXTVERSION)next--$(EXTVERSION).sql; \
+ $(INSTALL_DATA) $^ "$${todir}/$${tpl}"; \
for OLD_VERSION in $(UPGRADEABLE_VERSIONS); do \
- ln -fs $(EXTENSION)--ANY-$(EXTVERSION).sql sql/$(EXTENSION)--$$OLD_VERSION--$(EXTVERSION).sql; \
+ ln -fs "$${tpl}" $${todir}/$(EXTENSION)--$$OLD_VERSION--$(EXTVERSION).sql; \
done
distclean: clean
