[postgis-tickets] [PostGIS] #3884: topology failures in trunk
trac at osgeo.org
Fri Oct 6 18:03:23 PDT 2017
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.5.0
Component: postgis | Version: trunk
Keywords: |
This seems to be happening on all bots
regress/topogeo_addlinestring .. failed (diff expected obtained:
/var/lib/jenkins/workspace/postgis/tmp/2_5_pg9.6w64/test_29_diff)
--- regress/topogeo_addlinestring_expected 2017-10-06
21:25:46.075418731 +0000
+++ /var/lib/jenkins/workspace/postgis/tmp/2_5_pg9.6w64/test_29_out
2017-10-06 21:26:12.335413798 +0000
@@ -186,8 +186,7 @@
t3280.end|Topology 'bug3280' dropped
t3380.start|t
t3380.L1|1
-t3380.L2|3
-t3380.L2|4
+ERROR: Invalid edge (no two distinct vertices exist)
t3380.L3|5
t3380.end|Topology 'bug3380' dropped
t3402.start|t
I'tm guessing this isn't caused by topology directly but because of
pramsey vaccuming and dusting in #3877
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3884>
