[postgis-tickets] [PostGIS] #3884: topology failures in trunk
PostGIS trac at osgeo.org
Fri Oct 6 18:06:29 PDT 2017
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.5.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Description changed by robe:
Old description:
> This seems to be happening on all bots
>  regress/topogeo_addlinestring .. failed (diff expected obtained:
> /var/lib/jenkins/workspace/postgis/tmp/2_5_pg9.6w64/test_29_diff)
> --- regress/topogeo_addlinestring_expected      2017-10-06
> 21:25:46.075418731 +0000
> +++ /var/lib/jenkins/workspace/postgis/tmp/2_5_pg9.6w64/test_29_out
> 2017-10-06 21:26:12.335413798 +0000
> @@ -186,8 +186,7 @@
>  t3280.end|Topology 'bug3280' dropped
>  t3380.start|t
>  t3380.L1|1
> -t3380.L2|3
> -t3380.L2|4
> +ERROR:  Invalid edge (no two distinct vertices exist)
>  t3380.L3|5
>  t3380.end|Topology 'bug3380' dropped
>  t3402.start|t
> I'tm guessing this isn't caused by topology directly but because of
> pramsey vaccuming and dusting in #3877
New description:
 @@ -186,8 +186,7 @@
  t3380.start|t
  t3380.L1|1
 -t3380.L2|3
 -t3380.L2|4
  t3380.L3|5
  t3402.start|t
 pramsey vaccuming and dusting in #3877.
 Issue started happening at r15925
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3884#comment:1>
