[postgis-tickets] r15929 - Report which upgrade failed
Sandro Santilli
strk at kbt.io
Sat Oct 7 06:39:38 PDT 2017
Author: strk
Date: 2017-10-07 06:39:38 -0700 (Sat, 07 Oct 2017)
New Revision: 15929
trunk/utils/check_all_upgrades.sh
Modified: trunk/utils/check_all_upgrades.sh
--- trunk/utils/check_all_upgrades.sh 2017-10-07 13:39:31 UTC (rev 15928)
+++ trunk/utils/check_all_upgrades.sh 2017-10-07 13:39:38 UTC (rev 15929)
@@ -17,7 +17,10 @@
if test -e postgis--${UPGRADE_PATH}.sql; then
echo "Testing upgrade $UPGRADE_PATH"
export RUNTESTFLAGS="-v --extension --upgrade-path=${UPGRADE_PATH}"
- make -C ${BUILDDIR}/regress check || exit 1
+ make -C ${BUILDDIR}/regress check || {
+ echo "Upgrade $UPGRADE_PATH failed" >&2
+ exit 1
else
echo "Missing script for $UPGRADE_PATH upgrade" >&2
fi
