[postgis-tickets] r15930 - Keep running on failure, report all pass/fail/skip at the end
Sandro Santilli
strk at kbt.io
Sat Oct 7 06:39:45 PDT 2017
Author: strk
Date: 2017-10-07 06:39:45 -0700 (Sat, 07 Oct 2017)
New Revision: 15930
trunk/utils/check_all_upgrades.sh
Modified: trunk/utils/check_all_upgrades.sh
--- trunk/utils/check_all_upgrades.sh 2017-10-07 13:39:38 UTC (rev 15929)
+++ trunk/utils/check_all_upgrades.sh 2017-10-07 13:39:45 UTC (rev 15930)
@@ -10,18 +10,23 @@
EXTDIR=`pg_config --sharedir`/extension/
cd $EXTDIR
-'ls' postgis--* | grep -v -- '--.*--' |
-sed 's/^postgis--\(.*\)\.sql/\1/' | while read fname; do
+failures=0
+files=`'ls' postgis--* | grep -v -- '--.*--' | sed 's/^postgis--\(.*\)\.sql/\1/'`
+for fname in $files; do
from_version="$fname"
UPGRADE_PATH="${from_version}--${to_version}"
if test -e postgis--${UPGRADE_PATH}.sql; then
echo "Testing upgrade $UPGRADE_PATH"
export RUNTESTFLAGS="-v --extension --upgrade-path=${UPGRADE_PATH}"
- make -C ${BUILDDIR}/regress check || {
- echo "Upgrade $UPGRADE_PATH failed" >&2
- exit 1
+ make -C ${BUILDDIR}/regress check && {
+ echo "PASS: upgrade $UPGRADE_PATH"
+ echo "FAIL: upgrade $UPGRADE_PATH"
+ failures=$((failures+1))
else
- echo "Missing script for $UPGRADE_PATH upgrade" >&2
+ echo "SKIP: upgrade $UPGRADE_PATH is missing"
fi
done
+exit $failures
