[postgis-tickets] [PostGIS] #3892: Review safety and behavior of CREATE EXTENSION from UNPACKAGED
trac at osgeo.org
Mon Oct 9 23:05:49 PDT 2017
Reporter: strk | Owner: pramsey
Type: task | Status: new
Priority: high | Milestone: PostGIS 2.4.1
Component: postgis | Version: 2.4.x
Resolution: | Keywords:
Comment (by robe):
In all cases, the unpackaged would fail if it tries to add a type,
function, agg that is not installed so I think the worse case scenario of
your lib pointing at 2.2 but your unpackaged stamps it as 2.4 is accounted
for
Worst case is they don't have an installation of what they came from so no
unpackaged script for them to run so they are stuck unpackaged because the
only ones available error out.
If the unpackaged actually works, then what postgresql thinks you are
running is not what you have installed.
For this case
SELECT postgis_full_version();
Would show the inconsistency. However postgis_full_version() doesn't tell
them what to do if their postgis extension say they are at 2.4.1 but they
are really at 2.4.0.
So postgis_full_version() whould need to look at the
pg_available_extensions.installed_version and compare it to what
postgis_lib_version() says and if it's different and
pg_available_extensions.installed_version =
pg_available_extensions.default_version
tell them the need to run
ALTER EXTENSION postgis UPDATE TO "2.4.1next";
ALTER EXTENSION postgis UPDATE TO "2.4.1";
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3892#comment:5>
