[postgis-tickets] [PostGIS] #3892: Review safety and behavior of CREATE EXTENSION from UNPACKAGED
trac at osgeo.org
Mon Oct 9 23:41:10 PDT 2017
Reporter: strk | Owner: pramsey
Type: task | Status: new
Priority: high | Milestone: PostGIS 2.4.1
Component: postgis | Version: 2.4.x
Resolution: | Keywords:
Comment (by strk):
> Worst case is they don't have an installation of what they came from
> so no unpackaged script for them to run so they are stuck unpackaged
> because the only ones available error out.
In this case it would be nice of us to make the "FROM unpackaged"
embed an upgrade, wouldn't it ?
> If the unpackaged actually works, then what postgresql thinks you are
> running is not what you have installed.
This case would also be fixed if we make the "FROM unpackaged"
embed an upgrade, right ?
> So postgis_full_version() whould need to look at the
> pg_available_extensions.installed_version and compare it to what
> postgis_lib_version() says
Could you ticket this one separately, it's a good idea !
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3892#comment:6>
