[postgis-tickets] [PostGIS] #3896: postgis_extension_upgrade function to upgrade all your packaged postgis extensions
trac at osgeo.org
Wed Oct 11 01:48:13 PDT 2017
extensions
Reporter: robe | Owner: strk
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.5.0
Component: build/upgrade/install | Version: trunk
Keywords: |
One of the annoyances of having so many postgis extensions is having to
remember to upgrade all of them when you install a new postgis.
This function would check to see what extensions of postgis you have
installed and upgrade them to the latest. I put in the noraster bit with
the mindset that if we encode the noraster version in the version as I had
proposed
then this function can be used to check which version of postgis a user
has and upgrade them to the right one (with or without raster). So if
they have the noraster edition, it would upgrade them to the next noraster
version regardless what the default is set to in postgis.control. That
would allow us to make the noraster be the default and users who want
raster, would have to install using
CREATE EXTENSION postgis VERSION "2.5.0";
CREATE OR REPLACE FUNCTION postgis_extension_upgrade() RETURNS void AS
BEGIN
DECLARE rec record; BEGIN for rec in SELECT 'ALTER EXTENSION ' || name ||
' UPDATE TO "' || CASE WHEN installed_version ILIKE '%noraster' THEN
replace(default_version,'noraster','') ||'noraster' ELSE
replace(default_version,'noraster','') END || '";' AS sql
FROM pg_available_extensions
WHERE installed_version > '' AND name IN('address_standardizer',
'postgis', 'postgis_sfcgal', 'postgis_tiger_geocoder', 'postgis_topology')
and ( replace(default_version,'noraster','') <> replace(installed_version,
'noraster','') ) LOOP
EXECUTE rec.sql;
RAISE NOTICE '%', rec.sql;
END LOOP; END;
END
$$ language plpgsql;
I tested using a database that has sfcgal and postgis installed at 2.3.1
NOTICE showed this:
NOTICE: ALTER EXTENSION postgis UPDATE TO "2.4.0";
CONTEXT: PL/pgSQL function postgis_extension_upgrade() line 9 at RAISE
NOTICE: ALTER EXTENSION postgis_sfcgal UPDATE TO "2.4.0";
We could also maybe allow the function to take in an argument.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3896>
