[postgis-tickets] [PostGIS] #3896: postgis_extensions_upgrade function to upgrade all your packaged postgis extensions (was: postgis_extension_upgrade function to upgrade all your packaged postgis extensions)
trac at osgeo.org
Wed Oct 11 01:51:05 PDT 2017
extensions
Reporter: robe | Owner: strk
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.5.0
Component: build/upgrade/install | Version: trunk
Resolution: | Keywords:
Description changed by robe:
Old description:
> One of the annoyances of having so many postgis extensions is having to
> remember to upgrade all of them when you install a new postgis.
> This function would check to see what extensions of postgis you have
> installed and upgrade them to the latest. I put in the noraster bit with
> the mindset that if we encode the noraster version in the version as I
> had proposed
> then this function can be used to check which version of postgis a user
> has and upgrade them to the right one (with or without raster). So if
> they have the noraster edition, it would upgrade them to the next
> noraster version regardless what the default is set to in
> postgis.control. That would allow us to make the noraster be the default
> and users who want raster, would have to install using
> CREATE EXTENSION postgis VERSION "2.5.0";
> CREATE OR REPLACE FUNCTION postgis_extension_upgrade() RETURNS void AS
> BEGIN
> DECLARE rec record; BEGIN for rec in SELECT 'ALTER EXTENSION ' || name
> || ' UPDATE TO "' || CASE WHEN installed_version ILIKE '%noraster' THEN
> replace(default_version,'noraster','') ||'noraster' ELSE
> replace(default_version,'noraster','') END || '";' AS sql
> FROM pg_available_extensions
> WHERE installed_version > '' AND name IN('address_standardizer',
> 'postgis', 'postgis_sfcgal', 'postgis_tiger_geocoder',
> 'postgis_topology')
> and ( replace(default_version,'noraster','') <>
> replace(installed_version, 'noraster','') ) LOOP
> EXECUTE rec.sql;
> RAISE NOTICE '%', rec.sql;
> END LOOP; END;
> END
> $$ language plpgsql;
> I tested using a database that has sfcgal and postgis installed at 2.3.1
> NOTICE showed this:
> NOTICE: ALTER EXTENSION postgis UPDATE TO "2.4.0";
> CONTEXT: PL/pgSQL function postgis_extension_upgrade() line 9 at RAISE
> NOTICE: ALTER EXTENSION postgis_sfcgal UPDATE TO "2.4.0";
> We could also maybe allow the function to take in an argument.
New description:
the mindset that if we encode the noraster version in the version as I had
proposed
they have the noraster edition, it would upgrade them to the next noraster
version regardless what the default is set to in postgis.control. That
would allow us to make the noraster be the default and users who want
CREATE OR REPLACE FUNCTION postgis_extensions_upgrade() RETURNS void AS
BEGIN
DECLARE rec record; BEGIN for rec in SELECT 'ALTER EXTENSION ' || name ||
'postgis', 'postgis_sfcgal', 'postgis_tiger_geocoder', 'postgis_topology')
and ( replace(default_version,'noraster','') <> replace(installed_version,
EXECUTE rec.sql;
END LOOP; END;
END
NOTICE showed this:
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3896#comment:1>
