[postgis-tickets] [PostGIS] #3896: postgis_extensions_upgrade function to upgrade all your packaged postgis extensions
trac at osgeo.org
Wed Oct 11 10:11:50 PDT 2017
extensions
Reporter: robe | Owner: strk
Type: enhancement | Status: closed
Priority: medium | Milestone: PostGIS 2.5.0
Component: build/upgrade/install | Version: trunk
Resolution: fixed | Keywords:
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"15970" 15970]:
#!CommitTicketReference repository="" revision="15970"
postgis_extensions_upgrade(). Can't remember which postgis extensions you
installed and are two lazy to figure out and upgrade each with ALTER
EXTENSION.
just do
SELECT postgis_extensions_upgrade();
Closes #3896
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3896#comment:9>
