[postgis-tickets] [PostGIS] #3896: postgis_extensions_upgrade function to upgrade all your packaged postgis extensions
trac at osgeo.org
Wed Oct 11 10:30:26 PDT 2017
extensions
Reporter: robe | Owner: strk
Type: enhancement | Status: reopened
Priority: medium | Milestone: PostGIS 2.5.0
Component: build/upgrade/install | Version: trunk
Resolution: | Keywords:
Changes (by robe):
* status: closed => reopened
* resolution: fixed =>
Comment:
I didn't include noraster in this version, but realized I should probably
include the special case of dev upgrade. when both installed version and
default version have "dev" in the name.
So dev should always upgrade regardless of if it is the same as the
default_version.
Soo if installed_version has dev in the name (but no next), we should
upgrade to the "next" version. If it has "next" then take out the "next"
if it has a "next". This we can test as part of our upgrade tests.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3896#comment:10>
