[postgis-tickets] [PostGIS] #3898: ANY-2.5.0dev is showing as an upgrade option
PostGIS trac at osgeo.org
Thu Oct 12 21:05:26 PDT 2017
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 2.5.0
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:  fixed                  |   Keywords:
Comment (by robe):
 But wait. It's not working on winnie
 and been failing for quite sometime.  Longer than I keep logs for.
 https://debbie.postgis.net:444/job/PostGIS_EDB_Regress_winnie/5936/consoleFull
 Upgrading PostGIS in 'postgis_reg' using: ALTER EXTENSION postgis UPDATE
 TO '2.5.0devnext'
 Died at run_test.pl line 1423.
  failed (Error encountered altering EXTENSION POSTGIS:
 /projects/postgis/tmp/2.5.0dev_pg10_geos3.7.0dev_gdal2.2.2w32/regress_log)
 sh: createlang: command not found
 CREATE EXTENSION
 CREATE EXTENSION
 ERROR:  extension "postgis" has no update path from version "2.5.0dev" to
 version "2.5.0devnext"
 make[1]: *** [Makefile:303: check] Error 1
 make[1]: Leaving directory '/projects/postgis/branches/2.5/regress'
 make: *** [GNUmakefile:16: check] Error 1
 I'll ticket as separate issue might be the way I install on winnie, cause
 files get installed on the mingw but I copy over to the  VC++ build.
 Though locally I'm testing vc++ build.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3898#comment:7>
