[postgis-tickets] [PostGIS] #3898: ANY-2.5.0dev is showing as an upgrade option
trac at osgeo.org
Fri Oct 13 08:54:20 PDT 2017
Reporter: robe | Owner: strk
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.5.0
Component: build/upgrade/install | Version: trunk
Resolution: fixed | Keywords:
Comment (by strk):
What I see on last winnie buildi is this:
Test: test_kmeans ...Makefile:86: recipe for target 'check' failed
make[2]: *** [check] Segmentation fault
REF:
https://debbie.postgis.net:444/view/PostGIS/job/PostGIS_EDB_Regress_winnie/5943/console
Where are you seing the missing update path ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3898#comment:8>
