[postgis-tickets] [PostGIS] #3838: topology.toTopoGeom fails with ERROR: XX000: SQL/MM Spatial exception - geometry crosses, when using tolerance 10 meter
trac at osgeo.org
Wed Oct 18 00:23:27 PDT 2017
Reporter: laopsahl | Owner: strk
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 2.3.4
Component: topology | Version: 2.3.x
Resolution: | Keywords: totopogeom, ERROR: XX000: SQL/MM
Comment (by laopsahl):
Hi
I have tested something like this (see attachments just added).
The logic I tested , was that before I start i reduce the tolerance I I
try to add simple pieces of lines like this.
1) If I get a exception I try to adde each single piece of the line. This
means that if the line has 5 points, I try add 4 line pieces in a separate
operations using the original tolerance.
2) If I still get a exception on a line piece with only 2 points, the I
try to reduce the tolerance in steps 1 meter down to zero meter.
With this approach I also fails to add all lines, here is description of
the attachments above.
I start with this break_up_reduce_1 (light yellow existing data, red new
lines add)
The I get this result break_up_reduce_2.png (The green lines are valid
edges, the light red dotted lines are line pieces that I failed to add)
After using the approach above I end with non closed polygons because I
fails to add the red red dotted part of the new data, so I end with a non
closed polygons.
So for me it seems fail even if I add a single line with two points and
tolerance 0. It does not happen often but it happens.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3838#comment:9>
