[postgis-tickets] [PostGIS] #3838: topology.toTopoGeom fails with ERROR: XX000: SQL/MM Spatial exception - geometry crosses, when using tolerance 10 meter
trac at osgeo.org
Fri Oct 20 00:10:11 PDT 2017
Reporter: laopsahl | Owner: strk
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 2.3.5
Component: topology | Version: 2.3.x
Resolution: | Keywords: totopogeom, ERROR: XX000: SQL/MM
Comment (by laopsahl):
The case where we have less distance between the points in the data and
input, than the tolerance we use is quite important to handle, because we
get data from different sources. One source we use is users who are
actually drawing on the screen, in this case we testing input based on
images. The data we are updating are mostly in it's original form draw by
user using in some way.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3838#comment:11>
