[postgis-tickets] [PostGIS] #3838: topology.toTopoGeom fails with ERROR: XX000: SQL/MM Spatial exception - geometry crosses, when using tolerance 10 meter
trac at osgeo.org
Fri Oct 20 02:25:47 PDT 2017
Reporter: laopsahl | Owner: strk
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 2.3.5
Component: topology | Version: 2.3.x
Resolution: | Keywords: totopogeom, ERROR: XX000: SQL/MM
Comment (by strk):
The point is: if you tolerate 10 meters, you should not allow lines with
points closer than 10 meters each other. Those lines, even if drawn by
users, can be cleaned up before being sent to the topology, using
ST_RemoveRepeatedPoints or ST_Simplify. An already-built topology can also
be cleaned to a target tolerance by using the same functions and
ST_ChangeEdgeGeom.
That said, the snapping method used during topology building (implemented
in GEOS) is not stable enough, so it would be useful to rewrite it.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3838#comment:12>
