[postgis-tickets] r16003 - Prepare for 2.2.6 release
Paul Ramsey
pramsey at cleverelephant.ca
Wed Oct 18 09:13:20 PDT 2017
Author: pramsey
Date: 2017-10-18 09:13:20 -0700 (Wed, 18 Oct 2017)
New Revision: 16003
branches/2.2/ChangeLog
branches/2.2/NEWS
branches/2.2/README.postgis
branches/2.2/Version.config
branches/2.2/doc/release_notes.xml
branches/2.2/extensions/upgradeable_versions.mk
Modified: branches/2.2/ChangeLog
--- branches/2.2/ChangeLog 2017-10-17 20:37:34 UTC (rev 16002)
+++ branches/2.2/ChangeLog 2017-10-18 16:13:20 UTC (rev 16003)
@@ -1,3 +1,213 @@
+2017-10-17 16:55 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r15999] NEWS, liblwgeom/cunit/cu_geodetic.c, liblwgeom/g_box.c:
+ Allocate enough space for all possible GBOX string outputs (Raúl
+ Marín Rodríguez)
+ References #3907
+2017-10-10 22:44 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r15958] NEWS, liblwgeom/lwin_wkb.c: Throw error on malformed WKB
+ input (2.2 branch)
+ Credit to OSS-Fuzz:
+ https://bugs.chromium.org/p/oss-fuzz/issues/detail?id=2589
+ https://bugs.chromium.org/p/oss-fuzz/issues/detail?id=2590
+ https://bugs.chromium.org/p/oss-fuzz/issues/detail?id=2591
+ https://bugs.chromium.org/p/oss-fuzz/issues/detail?id=2592
+ (References #3895)
+2017-10-10 18:04 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r15953] NEWS, liblwgeom/lwout_encoded_polyline.c: Undefined
+ behaviour in pointarray_to_encoded_polyline (2.2 branch)
+ (References #3891)
+2017-10-10 16:59 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r15950] NEWS, liblwgeom/cunit/cu_varint.c, liblwgeom/varint.c,
+ liblwgeom/varint.h: Fix undefined behaviour in zigzag with
+ negative inputs (2.4 branch)
+ (References #3882)
+2017-10-10 16:37 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r15947] NEWS, liblwgeom/cunit/cu_measures.c,
+ liblwgeom/measures.c: lw_dist2d_pt_arc division by zero
+ (References #3874)
+2017-10-06 13:21 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r15921] NEWS, liblwgeom/lwalgorithm.c: geohash_point_as_int: Fix
+ undefined behaviour in shift operation
+ Closes #3875
+2017-10-06 13:18 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r15917] NEWS, liblwgeom/cunit/cu_libgeom.c,
+ liblwgeom/liblwgeom.h.in: Undefined behaviour in TYPMOD_GET_SRID
+ Closes #3880
+2017-10-05 13:21 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r15900] NEWS, liblwgeom/cunit/cu_geodetic.c,
+ liblwgeom/cunit/cu_libgeom.c, liblwgeom/liblwgeom_internal.h,
+ liblwgeom/lwalgorithm.c, liblwgeom/lwgeodetic.c,
+ liblwgeom/lwgeodetic.h, liblwgeom/lwspheroid.c: Combine multiple
+ signum definitions (2.2)
+ (References #3878)
+2017-10-05 13:04 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r15899] NEWS, liblwgeom/cunit/cu_measures.c,
+ liblwgeom/measures.c: division by zero in lw_dist2d_arc_arc
+ Closes #3879
+2017-10-02 06:21 Sandro Santilli <strk at keybit.net>
+ * [r15868] NEWS, liblwgeom/Makefile.in: Add -lm to liblwgeom link
+ line
+ Closes #3869 in 2.2 branch
+2017-09-30 17:47 Sandro Santilli <strk at keybit.net>
+ * [r15862] .drone.yml: Fix yaml syntax in drone config
+2017-09-26 19:49 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r15839] NEWS: TWKB news item (Closes #3866)
+2017-09-26 19:10 Nicklas Avén <nicklas.aven at jordogskog.no>
+ * [r15836] liblwgeom/bytebuffer.c: increase possible size of varint
+2017-09-20 21:27 Regina Obe <lr at pcorp.us>
+ * [r15781] .travis.yml: try to get travis to regress by fixing
+ permission issues.
+ References #3856 for PostGIS 2.2
+2017-09-20 03:52 Regina Obe <lr at pcorp.us>
+ * [r15777] NEWS, postgis/postgis.sql.in: ST_ConcaveHull fix for
+ ExteriorRing is not a polygon
+ Closes #2836 for PostGIS 2.2.6
+2017-09-18 21:59 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r15763] NEWS: News item (references #3731)
+2017-09-18 14:46 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r15760] NEWS: Added NEWS entry (references #3774)
+2017-09-18 13:28 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r15757] liblwgeom/lwcompound.c: Trig length calculation for
+ compound curve in 2.2 (references #3774)
+2017-09-14 22:58 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r15741] postgis/gserialized_estimate.c: #3731, backend crash on
+ zero size stats histogram
+2017-09-14 14:04 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r15725] extensions/address_standardizer/gamma.c,
+ loader/dbfopen.c, loader/pgsql2shp-core.c,
+ loader/shp2pgsql-core.c, raster/loader/raster2pgsql.c: #3847,
+ coverity fixes for 2.2
+2017-09-13 20:30 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r15719] doc/extras_topology.xml: Fix misplaced section end
+2017-09-13 20:21 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r15715] doc/extras_topology.xml: #3249, #2352, document
+ ST_RemoveIsoEdge
+2017-09-11 16:39 Sandro Santilli <strk at keybit.net>
+ * [r15687] .drone.yml: [drone] extract target upgrade version
+ dynamically
+ also disable interrupt tests
+2017-09-05 16:58 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r15626] liblwgeom/cunit/cu_geos.c, liblwgeom/lwgeom_geos.c:
+ #3829 Segfault in LWGEOM2GEOS
+2017-09-04 00:14 Daniel Baston <dbaston at gmail.com>
+ * [r15619] doc/reference_measure.xml: #3499, Clarify distance units
+ in docs for ST_ClusterWithin
+2017-07-21 05:16 Regina Obe <lr at pcorp.us>
+ * [r15492] liblwgeom/ptarray.c: missed a spot. revert another const
+ add fix compile error
+2017-07-21 04:54 Regina Obe <lr at pcorp.us>
+ * [r15491] liblwgeom/ptarray.c: Get rid of const define for
+ ptarray_remove_repeated_points_minpoints, caused compile error
+2017-07-20 22:48 Regina Obe <lr at pcorp.us>
+ * [r15490] NEWS, liblwgeom/ptarray.c: Back port all changes since
+ Jan 2016.
+ References #3768 OSS Fuzz fixes
+ Correction of strk's email
+ formatting cleanup by strk
+ and adjustments to logic for readability by strk
+2017-06-24 06:17 Regina Obe <lr at pcorp.us>
+ * [r15462] .travis.yml: try to fix travis gdal related build error
+2017-06-24 05:40 Regina Obe <lr at pcorp.us>
+ * [r15461] doc/installation.xml: Specify highest version of
+ PostgreSQL supported.
+ Closes #3762 for PostGIS 2.2.6
+2017-06-06 12:28 Sandro Santilli <strk at keybit.net>
+ * [r15422] NEWS, doc/release_notes.xml: Speep up -> Speed up
+ Thanks Andreas Schild via
+ https://www.transifex.com/postgis/postgis/translate/#de/release_notesxmlpot/74993598/
+2017-06-06 12:22 Sandro Santilli <strk at keybit.net>
+ * [r15419] NEWS, doc/release_notes.xml: shp2pgsql locale fixes are
+ #3084, not #3048
+ https://www.transifex.com/postgis/postgis/translate/#de/release_notesxmlpot/74993584/
+2017-04-12 13:36 Sandro Santilli <strk at keybit.net>
+ * [r15353] README.md: Fix drone build badge url
+ [ci skip]
+2017-01-29 20:58 Regina Obe <lr at pcorp.us>
+ * [r15299] Version.config, extensions/upgradeable_versions.mk: flip
+ version to 2.2.6dev
+2017-01-29 19:59 Regina Obe <lr at pcorp.us>
+ * [r15297] ChangeLog, HOWTO_RELEASE, NEWS, README.postgis,
+ Version.config, doc/release_notes.xml: Prepare for PostGIS 2.2.5
+ release
2017-01-07 08:59 Regina Obe <lr at pcorp.us>
* [r15286] NEWS, postgis/gserialized_gist_2d.c,
Modified: branches/2.2/NEWS
--- branches/2.2/NEWS 2017-10-17 20:37:34 UTC (rev 16002)
+++ branches/2.2/NEWS 2017-10-18 16:13:20 UTC (rev 16003)
@@ -1,5 +1,5 @@
PostGIS 2.2.6
-2017/xx/xx
+2017/10/18
* Bug Fixes *
- #3786, ptarray null and heap issues on is_closed
Modified: branches/2.2/README.postgis
--- branches/2.2/README.postgis 2017-10-17 20:37:34 UTC (rev 16002)
+++ branches/2.2/README.postgis 2017-10-18 16:13:20 UTC (rev 16003)
@@ -1,8 +1,8 @@
PostGIS - Geographic Information Systems Extensions to PostgreSQL
-:Version: 2.2.5
-:Date: 2017-01-29
+:Version: 2.2.6
+:Date: 2017-10-18
:Website: http://postgis.net
This distribution contains a module which implements GIS simple features, ties
Modified: branches/2.2/Version.config
--- branches/2.2/Version.config 2017-10-17 20:37:34 UTC (rev 16002)
+++ branches/2.2/Version.config 2017-10-18 16:13:20 UTC (rev 16003)
@@ -5,7 +5,7 @@
POSTGIS_MAJOR_VERSION=2
POSTGIS_MINOR_VERSION=2
-POSTGIS_MICRO_VERSION=6dev
+POSTGIS_MICRO_VERSION=6
# Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
# when changing POSTGIS_MINOR_VERSION
Modified: branches/2.2/doc/release_notes.xml
--- branches/2.2/doc/release_notes.xml 2017-10-17 20:37:34 UTC (rev 16002)
+++ branches/2.2/doc/release_notes.xml 2017-10-18 16:13:20 UTC (rev 16003)
@@ -3,6 +3,29 @@
<title>Appendix</title>
<subtitle>Release Notes</subtitle>
<sect1>
+ <title>Release 2.2.6</title>
+ <para>Release date: 2017/10/18</para>
+ <para>This is a bug fix and performance improvement release.</para>
+ <simplesect>
+ <title>Bug Fixes and Enhancements</title>
+ <para>#3786, ptarray null and heap issues on is_closed</para>
+ <para>#3774, Trigonometric length for CompoundCurves</para>
+ <para>#3731, Crash on very small table of homogenous data</para>
+ <para>#2836, Receiving ERROR: ExteriorRing: geom is not a polygon with ST_ConcaveHull</para>
+ <para>#3866, Rare crash generating TWKB with large coordinate values</para>
+ <para>#3869, Fix build with "gold" linker</para>
+ <para>#3879, Division by zero in some arc cases</para>
+ <para>#3878, Single defn of signum in header</para>
+ <para>#3880, Undefined behaviour in TYPMOD_GET_SRID</para>
+ <para>#3875, Fix undefined behaviour in shift operation</para>
+ <para>#3874, lw_dist2d_pt_arc division by zero</para>
+ <para>#3882, undefined behaviour in zigzag with negative inputs</para>
+ <para>#3891, undefined behaviour in pointarray_to_encoded_polyline</para>
+ <para>#3895, throw error on malformed WKB input</para>
+ <para>#3907, Allocate enough space for all possible GBOX string outputs (Raúl Marín Rodríguez)</para>
+ </simplesect>
+ </sect1>
+ <sect1>
<title>Release 2.2.5</title>
<para>Release date: 2017/01/30</para>
Modified: branches/2.2/extensions/upgradeable_versions.mk
--- branches/2.2/extensions/upgradeable_versions.mk 2017-10-17 20:37:34 UTC (rev 16002)
+++ branches/2.2/extensions/upgradeable_versions.mk 2017-10-18 16:13:20 UTC (rev 16003)
@@ -16,10 +16,10 @@
2.1.6 \
2.1.7 \
2.1.8 \
- 2.1.9 \
- 2.2.0 \
- 2.2.1 \
- 2.2.2 \
- 2.2.3 \
- 2.2.4 \
- 2.2.5
+ 2.1.9 \
+ 2.2.0 \
+ 2.2.1 \
+ 2.2.2 \
+ 2.2.3 \
+ 2.2.4 \
+ 2.2.5
