[postgis-tickets] [PostGIS] #3909: Memory leak in lwgeom_remove_repeated_points_in_place
trac at osgeo.org
Wed Oct 18 12:40:57 PDT 2017
Reporter: Algunenano | Owner: strk
Type: defect | Status: closed
Priority: high | Milestone: PostGIS 2.5.0
Component: liblwgeom | Version: trunk
Resolution: fixed | Keywords:
Changes (by pramsey):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"16016" 16016]:
#!CommitTicketReference repository="" revision="16016"
Fix memory leak in lwgeom_remove_repeated_points_in_place
From Raúl Marín Rodríguez
Closes #3909
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3909#comment:1>
