[postgis-tickets] [PostGIS] #3912: glibtoolize doesn't install install-sh
PostGIS trac at osgeo.org
Sat Oct 21 02:08:33 PDT 2017
  Reporter:  pramsey  |      Owner:  strk
      Type:  defect   |     Status:  closed
  Priority:  medium   |  Milestone:  PostGIS 2.4.2
 Component:  postgis  |    Version:  2.4.x
Resolution:  fixed    |   Keywords:
Changes (by strk):
 * status:  assigned => closed
 * resolution:   => fixed
Comment:
 In [changeset:"16031" 16031]:
 #!CommitTicketReference repository="" revision="16031"
 Put build AUX files under build-aux
 Cleans and ignore build aux files from new location,
 and remove spurious install-sh from repository.
 Closes #3912 in 2.2 branch
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3912#comment:7>
