[postgis-tickets] [PostGIS] #3912: glibtoolize doesn't install install-sh
trac at osgeo.org
Wed Oct 25 20:06:25 PDT 2017
Reporter: pramsey | Owner: strk
Type: defect | Status: reopened
Priority: medium | Milestone: PostGIS 2.4.2
Component: postgis | Version: 2.4.x
Resolution: | Keywords:
Changes (by robe):
* status: closed => reopened
* resolution: fixed =>
Comment:
As noted in #3916 this change broke my ability to
make install.
For some reason @INSTALL@ is resolving to ../ instead of ../install-sh
Manually editing generated make files to add in install-sh works.
Also you have the milestone flagged wrong on this sinc eyou push it to 2.2
and I'd also like to yell and scream that you did not note this change in
the NEWS files.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3912#comment:8>
