[postgis-tickets] [PostGIS] #3838: topology.toTopoGeom fails with ERROR: XX000: SQL/MM Spatial exception - geometry crosses, when using tolerance 10 meter
trac at osgeo.org
Sun Oct 22 02:39:41 PDT 2017
Reporter: laopsahl | Owner: strk
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 2.3.5
Component: topology | Version: 2.3.x
Resolution: | Keywords: totopogeom, ERROR: XX000: SQL/MM
Comment (by strk):
As of commit 0911624e7570fb026cea56772ac746e64bf3a457 the merge request
fixes both failed_test.sql and failed_test_2.sql in addition to my
simplified reduction above *and* ticket #3718
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3838#comment:14>
