[postgis-tickets] [PostGIS] #3838: topology.toTopoGeom fails with ERROR: XX000: SQL/MM Spatial exception - geometry crosses, when using tolerance 10 meter
PostGIS trac at osgeo.org
Sun Oct 22 02:46:51 PDT 2017
  Reporter:  laopsahl    |      Owner:  strk
      Type:  defect      |     Status:  assigned
  Priority:  medium      |  Milestone:  PostGIS 2.3.5
 Component:  topology    |    Version:  2.3.x
Resolution:              |   Keywords:  totopogeom, ERROR:  XX000: SQL/MM
Comment (by strk):
 The PR also fixes #1855
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3838#comment:15>
