[postgis-tickets] [PostGIS] #1855: 'SQL/MM Spatial exception - curve not simple' exception at adding two polygons
trac at osgeo.org
Sun Oct 22 02:44:06 PDT 2017
polygons
Reporter: wimned | Owner: strk
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 2.5.0
Component: topology | Version: 2.0.x
Resolution: | Keywords:
Comment (by strk):
Both simplified cases are fixed with the PR suggested in #3838
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1855#comment:22>
