[postgis-tickets] [PostGIS] #1855: 'SQL/MM Spatial exception - curve not simple' exception at adding two polygons
PostGIS trac at osgeo.org
Sun Oct 22 02:46:34 PDT 2017
polygons
  Reporter:  wimned    |      Owner:  strk
      Type:  defect    |     Status:  assigned
  Priority:  medium    |  Milestone:  PostGIS 2.5.0
 Component:  topology  |    Version:  2.0.x
Resolution:            |   Keywords:
Comment (by strk):
 The original case is also fixed. As of
 0911624e7570fb026cea56772ac746e64bf3a457 from the merge request
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1855#comment:23>
