[postgis-tickets] [PostGIS] #1855: 'SQL/MM Spatial exception - curve not simple' exception at adding two polygons
trac at osgeo.org
Sun Oct 22 08:39:26 PDT 2017
polygons
Reporter: wimned | Owner: strk
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.5.0
Component: topology | Version: 2.0.x
Resolution: fixed | Keywords:
Changes (by strk):
* status: assigned => closed
* resolution: => fixed
Comment:
In [changeset:"16038" 16038]:
#!CommitTicketReference repository="" revision="16038"
Add tests for topology bug #1855
Previous commits fixes #1855 too
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1855#comment:24>
