[postgis-tickets] [PostGIS] #3838: topology.toTopoGeom fails with ERROR: XX000: SQL/MM Spatial exception - geometry crosses, when using tolerance 10 meter
PostGIS trac at osgeo.org
Sun Oct 22 08:39:17 PDT 2017
  Reporter:  laopsahl    |      Owner:  strk
      Type:  defect      |     Status:  closed
  Priority:  medium      |  Milestone:  PostGIS 2.3.5
 Component:  topology    |    Version:  2.3.x
Resolution:  fixed       |   Keywords:  totopogeom, ERROR:  XX000: SQL/MM
Changes (by strk):
 * status:  assigned => closed
 * resolution:   => fixed
Comment:
 In [changeset:"16037" 16037]:
 #!CommitTicketReference repository="" revision="16037"
 Add test for topology bug #3838
 Shows previous commits fix #3838
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3838#comment:17>
