[postgis-tickets] [PostGIS] #3838: topology.toTopoGeom fails with ERROR: XX000: SQL/MM Spatial exception - geometry crosses, when using tolerance 10 meter
trac at osgeo.org
Sun Oct 22 08:40:43 PDT 2017
Reporter: laopsahl | Owner: strk
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.5.0
Component: topology | Version: 2.3.x
Resolution: fixed | Keywords: totopogeom, ERROR: XX000: SQL/MM
Changes (by strk):
* milestone: PostGIS 2.3.5 => PostGIS 2.5.0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3838#comment:18>
