[postgis-tickets] [PostGIS] #3838: topology.toTopoGeom fails with ERROR: XX000: SQL/MM Spatial exception - geometry crosses, when using tolerance 10 meter
trac at osgeo.org
Wed Oct 25 04:15:02 PDT 2017
Reporter: laopsahl | Owner: strk
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.5.0
Component: topology | Version: 2.3.x
Resolution: fixed | Keywords: totopogeom, ERROR: XX000: SQL/MM
Comment (by laopsahl):
Thanks starting to be more robust now so I did a bigger test with the new
code.
I started with a simple feature data set of 92746 polygons (11657424
points) and another dataset of 8754 polygons (846345 points). Then I
convert both data sets to Postgis Topology and then I try to merge the
small data set into big data by using snapto in Postgis Topology. I then
get problem with for 747 of these points. Most of this errors will not
cause problems for the because we already have line there, but some
failing snapto will cause polygons not to close .
I will create new bug report with more example.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3838#comment:19>
