[postgis-tickets] r16050 - Ignore generated unpackaged check scripts
Sandro Santilli strk at kbt.io
Sun Oct 22 12:06:55 PDT 2017
Author: strk
Date: 2017-10-22 12:06:55 -0700 (Sun, 22 Oct 2017)
New Revision: 16050
   trunk/.gitignore
[ci skip]
Modified: trunk/.gitignore
--- trunk/.gitignore	2017-10-22 19:06:49 UTC (rev 16049)
+++ trunk/.gitignore	2017-10-22 19:06:55 UTC (rev 16050)
@@ -48,6 +48,7 @@
 extensions/address_standardizer/us-*.sql
 extensions/postgis/Makefile
 extensions/postgis/postgis.control
+extensions/postgis/unpackaged_check.sql
 extensions/postgis/sql/
 extensions/postgis/sql_bits/*.sql
 extensions/postgis_sfcgal/Makefile
@@ -64,6 +65,7 @@
 extensions/postgis_tiger_geocoder/sql_bits/tiger_geocoder_minor.sql.in
 extensions/postgis_topology/Makefile
 extensions/postgis_topology/postgis_topology.control
+extensions/postgis_topology/unpackaged_check.sql
 extensions/postgis_topology/sql/
 extensions/postgis_topology/sql_bits/*.sql
 GNUmakefile
