[postgis-tickets] r16051 - Really only install symlinks for topology upgrade paths
Sandro Santilli strk at kbt.io
Sun Oct 22 12:20:34 PDT 2017
Author: strk
Date: 2017-10-22 12:20:34 -0700 (Sun, 22 Oct 2017)
New Revision: 16051
   trunk/extensions/postgis_topology/Makefile.in
Also only symlink the "next" hacks, and do all most of this at
`make install` time, not bothering at `make` time
Modified: trunk/extensions/postgis_topology/Makefile.in
--- trunk/extensions/postgis_topology/Makefile.in	2017-10-22 19:06:55 UTC (rev 16050)
+++ trunk/extensions/postgis_topology/Makefile.in	2017-10-22 19:20:34 UTC (rev 16051)
@@ -21,13 +21,24 @@
 DATA         = $(filter-out $(wildcard sql/*--*.sql),$(wildcard sql/*.sql))
+# Scripts making up the extension minor upgrade file
+# NOTE: order matters
+EXTENSION_UPGRADE_SCRIPTS = \
+	extlock.sql \
+	../postgis_extension_helper.sql \
+	sql_bits/remove_from_extension.sql.in \
+	sql/topology_upgrade.sql \
+	sql_bits/mark_editable_objects.sql.in \
+	sql_bits/topology_comments.sql \
+	../postgis_extension_helper_uninstall.sql
 PG_CONFIG    = @PG_CONFIG@
 SQL_BITS     = $(wildcard sql_bits/*.sql)
 EXTRA_CLEAN += sql/*.sql ${SQL_BITS}
-all: sql/$(EXTENSION)--$(EXTVERSION).sql sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql sql/$(EXTENSION)--$(EXTVERSION)--$(EXTVERSION)next.sql sql/$(EXTENSION)--$(EXTVERSION)next--$(EXTVERSION).sql sql_minor_upgrade
+all: sql/$(EXTENSION)--$(EXTVERSION).sql sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql sql_minor_upgrade
 sql/$(EXTENSION)--$(EXTVERSION).sql: sql/$(EXTENSION).sql
 	mkdir -p sql
@@ -37,12 +48,6 @@
 	mkdir -p sql
 	cat $^ > $@
-#this is a cludge to allow upgrading from same SVN to same SVN
-sql/$(EXTENSION)--$(EXTVERSION)--$(EXTVERSION)next.sql: extlock.sql ../postgis_extension_helper.sql sql_bits/remove_from_extension.sql.in sql/topology_upgrade.sql sql_bits/mark_editable_objects.sql.in sql_bits/topology_comments.sql ../postgis_extension_helper_uninstall.sql
-	cat $^ > $@
-sql/$(EXTENSION)--$(EXTVERSION)next--$(EXTVERSION).sql: sql/$(EXTENSION)--$(EXTVERSION)--$(EXTVERSION)next.sql
-	cat $^ > $@
 #strip BEGIN/COMMIT since these are not allowed in extensions
 #strip CREATE SCHEMA since we force extension
 # to create schema by setting schema to topology in control
@@ -78,9 +83,24 @@
 	mkdir -p sql
 	sed -e 's/BEGIN;//g' -e 's/COMMIT;//g' -e '/^CREATE SCHEMA/d;'  $< > $@
-sql_minor_upgrade: extlock.sql ../postgis_extension_helper.sql sql_bits/remove_from_extension.sql.in sql/topology_upgrade.sql sql_bits/mark_editable_objects.sql.in sql_bits/topology_comments.sql ../postgis_extension_helper_uninstall.sql
+sql_minor_upgrade: sql/$(EXTENSION)--ANY--$(EXTVERSION).sql
+sql/$(EXTENSION)--ANY--$(EXTVERSION).sql: $(EXTENSION_UPGRADE_SCRIPTS)
+	cat $(EXTENSION_UPGRADE_SCRIPTS) > $@
+EXTDIR=$(DESTDIR)$(datadir)/$(datamoduledir)
+install: install-upgrade-paths
+# The "next" lines are a cludge to allow upgrading between different
+# revisions of the same version
+install-upgrade-paths: sql/$(EXTENSION)--ANY--$(EXTVERSION).sql
+	tpl='$(EXTENSION)--ANY--$(EXTVERSION).sql'; \
+	$(INSTALL_DATA) $^ "$(EXTDIR)/$${tpl}"; \
+	ln -fs "$${tpl}" $(EXTDIR)/$(EXTENSION)--$(EXTVERSION)--$(EXTVERSION)next.sql; \
+	ln -fs "$${tpl}" $(EXTDIR)/$(EXTENSION)--$(EXTVERSION)next--$(EXTVERSION).sql; \
 	for OLD_VERSION in $(UPGRADEABLE_VERSIONS); do \
-  	  cat $^ > sql/$(EXTENSION)--$$OLD_VERSION--$(EXTVERSION).sql; \
+		ln -fs "$${tpl}" $(EXTDIR)/$(EXTENSION)--$$OLD_VERSION--$(EXTVERSION).sql; \
 	done
 DATA = $(wildcard sql/*--*.sql)
