[postgis-tickets] [PostGIS] #3825: Running an ST_Intersect with PostGIS Geography with large extents returns incorrect results.
PostGIS trac at osgeo.org
Mon Oct 23 15:28:28 PDT 2017
incorrect results.
  Reporter:  just7460  |      Owner:  pramsey
      Type:  defect    |     Status:  closed
  Priority:  medium    |  Milestone:  PostGIS 2.3.4
 Component:  postgis   |    Version:  2.3.x
Resolution:  wontfix   |   Keywords:  Geography, postgis
Comment (by just7460):
 I understand that it has been some time since we discussed this issue, but
 can you provide with an update, or a location to make suggestions, on
 support for features larger than a half-hemisphere?
 This is a large problem for us as our customers expect to be able to see
 their data at 'full extent' (global scale). SQL Server originally had
 issues with features larger than half a hemisphere, but they've resolved
 this issue since SQL Server 2008.
 Looking forward to your response!
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3825#comment:2>
