[postgis-tickets] [PostGIS] #3825: Running an ST_Intersect with PostGIS Geography with large extents returns incorrect results.
PostGIS trac at osgeo.org
Mon Oct 23 20:05:33 PDT 2017
incorrect results.
  Reporter:  just7460  |      Owner:  pramsey
      Type:  defect    |     Status:  closed
  Priority:  medium    |  Milestone:  PostGIS 2.3.4
 Component:  postgis   |    Version:  2.3.x
Resolution:  wontfix   |   Keywords:  Geography, postgis
Comment (by robe):
 You could put in another ticket as a feature request, to handle more than
 half-hemisphere for geography.
 pramsey would have to respond how much work that would be, as I presume we
 would have to also put restrictions on polygon orientation.  As I recall I
 think that's how SQL Server handle's it by assuming polygon draw
 direction.
 That said,  Things get a done a lot faster if people are willing to fund
 the effort. You should express your willingness to fund the work in your
 ticket.
 Thanks,
 Regina
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3825#comment:3>
