[postgis-tickets] r16057 - add ignore files
Paul Ramsey pramsey at cleverelephant.ca
Tue Oct 24 12:58:20 PDT 2017
Author: pramsey
Date: 2017-10-24 12:58:19 -0700 (Tue, 24 Oct 2017)
New Revision: 16057
   trunk/
   trunk/extensions/postgis/
   trunk/extensions/postgis_topology/
add ignore files
Property changes on: trunk
___________________________________________________________________
Modified: svn:ignore
   - aclocal.m4
autom4te.cache
configure
config.h
config.guess
config.log
config.status
config.sub
GNUmakefile
install-sh
libtool
ltmain.sh
Makefile.config
postgis_config.h
postgis_svn_revision.h
svnrevision.h
   + aclocal.m4
autom4te.cache
build-aux
configure
config.h
config.guess
config.log
config.status
config.sub
GNUmakefile
install-sh
libtool
ltmain.sh
Makefile.config
postgis_config.h
svnrevision.h
Property changes on: trunk/extensions/postgis
   - Makefile
postgis.control
   + Makefile
postgis.control
unpackaged_check.sql
Property changes on: trunk/extensions/postgis_topology
   - Makefile
postgis_topology.control
sql
   + Makefile
sql
