[postgis-tickets] [PostGIS] #3915: Feature Request: Support features larger than a half-hemisphere with PostGIS Geography.
PostGIS trac at osgeo.org
Wed Oct 25 09:35:31 PDT 2017
PostGIS Geography.
 Reporter:  just7460            |      Owner:  pramsey
     Type:  enhancement         |     Status:  new
 Priority:  medium              |  Milestone:  PostGIS 2.5.0
Component:  postgis             |    Version:  2.4.x
 Keywords:  Geography, postgis  |
 SYNOPSIS
 The documentation states the following:
 What is the longest arc you can process?
 We use great circle arcs as the "interpolation line" between two points.
 That means any two points are actually joined up two ways, depending on
 which direction you travel along the great circle. All our code assumes
 that the points are joined by the *shorter* of the two paths along the
 great circle. As a consequence, shapes that have arcs of more than 180
 degrees will not be correctly modelled.
 This is an issue when users want to create larger features, or, maybe even
 more importantly, when an envelope is passed which is greater than this
 limit (i.e. displaying all capital cities in the world, which uses a
 spatial envelop, will return incorrect results).
 SQL Server used to have this limitation as well; however, as of SQL Server
 2008, they provided a solution that eliminates this limitation.
 I wanted to put in a request for an enhancement to resolve this issue.
 Thank you for your consideration.
 POSTGRESQL SPECIFIC INFORMATION:
 Version:
 "PostgreSQL 9.6.3, compiled by Visual C++ build 1800, 64-bit"
 Special Installation requirements:
 N/A
 Special startup parameters:
 N/A
 OPERATING SYSTEM INFORMATION:
 OS: Windows 8.1 Enterprise
 Processor: Intel® Xeon® CPU E5-1620 v3 @ 3.50GHz
 System type: 64-bit Operating System, x64-based processor
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3915>
